Register Forgot Password?
Search
Notices
Old 01-01-2013, 05:38 PM   #1
dtcevo
Garage is empty, add now
dtcevo's Avatar
iTrader Rating: (0)
Default FS/WTT: K20 EK // Road Race Ready
All of my extra time over the last two years have gone into this. When I am not at a Grand Am race, I am in my shop messing with this. Its race ready. Just finished this last year. All parts have only two test days. I need to get new photo's of the finished interior. I will do that this week. For some reason I can't shake the desire for a rear wheel drive race car. So I am selling and/or trading for another race car, just RWD. Looking for a Mustang, Miata, BMW, S2000 or Nissan. Might even take the right RWD street car. If the 2013 season starts here in Utah and I have not found anything I will just race the Honda.
Price: 10k OBO
Contact: jdsmith at innovative-garage dot com
Text/call: 801-niner.one.eight-6130
Drivetrain: K20a2; fresh before install
* Type R cams
* RBC intake manifold, HPC coated
* DC swap header, HPC coated
* Hondata Kpro
* 2.5 in race exhaust, dumps at the rear control arm
* Karcepts A/C & P/S delete
* Karcepts Intake w/ velocity stack
* K-tuned black -6an fuel line kit w/ Aeromotive FPR
* Skunk2 composite fuel rail
* Complete Motorsports engine harness, recovered in Techflex PET
* EKK2 Hasport mounts, welded/gusseted to chassis for more rigidity,
* DC sub frame to move the motor lower and back in the chassis
* Setrab oil cooler, black element
* Samco black silicone radiator hoses
*Type R tranny 4.764 final
* Quaife LSD
* New OEM axles
Chassis:
*10pt cage, legal for SCCA, NASA and whatever else you want to race
* Cage is gusseted at A pillars, clearances are so close we were able to simply weld it at the base of the main hoop and top of the main hoop. Rear strut towers are boxed and braced
* Entire chassis harness pulled, lightened wrapped in Techflex, only necessities kept, new fuse block and relays
* Lots of engineering in the cage and chassis build, such as keep weight as centered as possible, we can discuss on purchase or a trade deal is made
* MOMO Safari helmet bolstered race seat.
* MOMO Mod 08 suede steering wheel with MOMO quick release
* OMP 5pt Hans compatible harness
* Dash is completely gutted, SI cluster, fuel switch, ignition switch, power switch, are all that are left
* All vents, radio and HVAC holes are plugged with honey comb carbon Kevlar custom pieces
* Shift box was elevated and moved closer to driver for ease/speed of shifting
Wheels, brakes:
* 15x9 4-100 35mm TRM
* 15mm front spacer; 10mm rear spacer; ARP extended studs
*Wilwood 12in, 4 piston BBK,
* EM SI rear disc brakes
* Goodridge stainless steel lines all around
* EM SI Brake master cylinder and booster
* ATE super blue DOT 4 fluid
Suspension:
*Progress coilovers, custom spring rates
*Hardrace front upper control arm, spherical bearing
*Hardrace front lower control arms, spherical bearing
*Hardrace rear upper control arm, spherical bearing
*Hardrace rear toe arms, spherical bearing
*PCI spherical bearing rear trailing arm bushings,
*Skunk2 rear lower control arms, custom spherical bearings
*Karcepts front swap hubs, allows use of 36mm axles, no more expensive swap axles
More pics and info on it here:
http://www.facebook.com/innovativegarage
http://innovative-garage.com/
Jason D. Smith
http://www.facebook.com/pages/Innova...884159?sk=wall
dtcevo is offline   Reply With Quote
Old 01-02-2013, 11:29 AM   #2
dischink_g0tph0
dischink_g0tph0's Avatar
iTrader Rating: (0)
Default Re: FS/WTT: K20 EK // Road Race Ready
Bump for Jason, legit seller and shop owner.
Seems like you took such a long time to build this and now its for sale =(
2001 Acura Integra Type R NHB #992 SOLD
1997 Acura Integra Type R NH-0 #309
dischink_g0tph0 is offline   Reply With Quote
Old 01-02-2013, 12:08 PM   #3
dtcevo
dtcevo's Avatar
iTrader Rating: (0)
I agree. I don't have much time these days. Did more racing in other peoples cars than building my own over the last two seasons. But I can't shake the wanting for an RWD race car. I just should have built a damn S2K!
Jason D. Smith
Old 01-02-2013, 12:41 PM   #4
95civc98
95civc98's Avatar
iTrader Rating: (0)
2003 330ci coupe?
95civc98 is offline   Reply With Quote
Old 01-02-2013, 01:11 PM   #5
dtcevo
dtcevo's Avatar
iTrader Rating: (0)
^^^What does it book for sir? That is a looong drive from NY.
Jason D. Smith
Old 01-02-2013, 01:20 PM   #6
95civc98
95civc98's Avatar
iTrader Rating: (0)
KBB in what i think my car is in good condition says $7,359 its white, all stock, factory navigation, H/K sound system, 5 speed, mileage is a little high 148,000 but the car is clean will get you pictures not sure what your plans are looks like you would turn whatever you get into a track car lol.
Old 01-02-2013, 03:30 PM   #7
dtcevo
dtcevo's Avatar
iTrader Rating: (0)
Either that or hock whatever I get and buy a RWD track car. There are some good deals out there. 7k is a a little low. My number is listed. Text me and maybe we can work something out.
Jason
Jason D. Smith
Old 01-03-2013, 06:50 PM   #8
dtcevo
dtcevo's Avatar
iTrader Rating: (0)
Sorry, I'm lagging. I still need to get interior shots posted.
Jason D. Smith
Old 01-03-2013, 07:49 PM   #9
DXB16Coupe
DXB16Coupe's Avatar
iTrader Rating: (0)
if this wasnt so far away id trade my S2000 for it GLWS!
DXB16Coupe is offline   Reply With Quote
Old 01-03-2013, 08:24 PM   #10
dtcevo
dtcevo's Avatar
iTrader Rating: (0)
^Where are you located sir? I am actually wanting to build an S2k.
Jason D. Smith
Old 01-03-2013, 09:17 PM   #11
macDelli
macDelli's Avatar
iTrader Rating: (0)
Great build bro glws
2000 Integra GSR / JDM Front / Bolt-on's
macDelli is offline   Reply With Quote
Old 01-03-2013, 10:21 PM   #12
DXB16Coupe
DXB16Coupe's Avatar
iTrader Rating: (0)
Unfortunately I'm all the way over in Ohio lol.
Old 01-05-2013, 08:19 PM   #13
dtcevo
dtcevo's Avatar
iTrader Rating: (0)
Thanks sir.
Want to try and work something out?
Jason D. Smith
Old 01-05-2013, 08:59 PM   #14
ngswimmer08
ngswimmer08's Avatar
iTrader Rating: (0)
Send a message via AIM to ngswimmer08
http://hondamarketplace.com/showthread.php?t=3114556
2000 Acura Integra DB7 Auto LS/VTEC - solddd
2006 Acura RSX Type S - solddd
1996 Honda Civic EK Hatch
ngswimmer08 is offline   Reply With Quote
Old 01-06-2013, 10:44 AM   #15
dtcevo
dtcevo's Avatar
iTrader Rating: (0)
Originally Posted by ngswimmer08 View Post
Value is a little low, but let's try and work something out. Call/text me, my number is listed.
Jason D. Smith
Old 01-06-2013, 01:21 PM   #16
DXB16Coupe
DXB16Coupe's Avatar
iTrader Rating: (0)
Thanks sir.
PM'D
Old 01-08-2013, 09:27 AM   #17
dtcevo
dtcevo's Avatar
iTrader Rating: (0)
Got it
Jason D. Smith
Old 01-14-2013, 11:06 AM   #18
dtcevo
dtcevo's Avatar
iTrader Rating: (0)
up
Jason D. Smith
Old 01-15-2013, 06:37 PM   #19
dtcevo
dtcevo's Avatar
iTrader Rating: (0)
Price lowered
Jason D. Smith
Old 01-15-2013, 08:19 PM   #20
moneymaker07893
iTrader Rating: (0)
http://hondamarketplace.com/showthread.php?t=3117597 plus cash on my end?
moneymaker07893 is offline   Reply With Quote
Old 01-18-2013, 11:38 AM   #21
dtcevo
dtcevo's Avatar
iTrader Rating: (0)
That's a long drive from New York sir.
Jason D. Smith
Old 01-19-2013, 03:20 AM   #22
superg6819
superg6819's Avatar
iTrader Rating: (0)
Send a message via AIM to superg6819
i don't see that you have listed how much hps its putting down? has this been on a dyno and do you have the sheet? Do you go to miller park often in the summer? Ive been there in my evo i try to go to every w.o.w. nights but only been to 3 of them since i just moved to the slc area last year.
2006 evo IX rs
superg6819 is offline   Reply With Quote
Old 01-19-2013, 06:02 AM   #23
MR EF8
iTrader Rating: (0)
Bump For A Local
OGSTATUS
MR EF8 is offline   Reply With Quote
Old 01-23-2013, 11:08 AM   #24
dtcevo
dtcevo's Avatar
iTrader Rating: (0)
We tuned it at the track. Makes about 220. Yes, I'm a driving instructor here at Miller Motorsports Park. I am here everyday. Car is stored here at the track you are welcome to come look at it if there is interest in the car.
Originally Posted by MR EF8 View Post
Bump For A Local
Thanks sir! I'm sure I know you, just don't recognize the HT name?
Jason D. Smith
Old 01-23-2013, 11:11 AM   #25
dtcevo
dtcevo's Avatar
iTrader Rating: (0)
Added interior pics. Sorry they are cell phone pics crappy at that. The interior actually cleans up very well. Just dusty in the pics
Jason D. Smith
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
