Register Forgot Password?
Search
Notices
Old 04-16-2011, 02:34 PM   #1
detroitdiscounts2000
Garage is empty, add now
detroitdiscounts2000's Avatar
iTrader Rating: (0)
Default 98 CIVIC FULLY BUILT TURBO D 423WHP 19 PSI TRADE
98 honda civic new paint NO RUST 90K ON BODY 423WHP ON 19PSI THIS WILL PUT DOWN OVER 600WHP WITH RACE GAS AND NEW TUNE IT RAN A 10.9 QUARTER MILE BUILT TO THE MAX BOOSTED D THERE'S LITTLE OVER 15K IN THE BUILD ALL DONE RIGHT DOES NOT BURN ANY OIL AT ALL LOPES LIKE A V8 AND MAINLY LOOKING TO TRADE AND I HAVE THE FRONT BUMPER AS WELL
everything is pretty new on the car ok TRADES IM LOOKING FOR MITSUBISHI EVO 350 z K SWAP INTEGRA RSX TYPE S WITH MODS IM SURE THERE IS SOME THINGS IM FORGETTING TO PUT DOWN BUT JUST LET ME KNOW WHAT U GOT LOOKING FOR K CARS cell 740 802-0761
MOTOR D16Y8/HEAD
edlebrock intake mani
supertech valve springs
titanium retainers and valves
all machine work valve job port and polish etc.
bisimoto 3.6 Cam
aem cam gear
new dizzy
msd plug wires
msd blaster coil
crane cams HI-6 capacitive discharge ignition
1200cc precision injectors
gm 2.5 map sensor
arp head studs
cometic head gasket
BOTTOM END
benson sleeved block
77mm cp pistons 9:1 compression
eagle rods acl race bearings
micro polish crank blueprinted etc
TURBO SET UP/ECU TRANN/
big holset turbo
synapse wastegate 15 psi spring
neukin ram horn
FLO racing products
greddy turbo timer
obx in line B.O.V etc
hondata s300
3 inch intercooler piping
trans carbon coated gears
Quaife LSD
reinforced shift forks spec clutch
Tein springs
integra sets
aem wideband
traction bars
c&r aluminum radiator
Click the image to open in full size.
detroitdiscounts2000 is offline   Reply With Quote
Old 04-16-2011, 05:30 PM   #2
bagged93civic
iTrader Rating: (0)
Default Re: 98 CIVIC FULLY BUILT TURBO D 423WHP 19 PSI TRADE
Bump for nice EK GLWS
bagged93civic is offline   Reply With Quote
Old 04-17-2011, 10:07 AM   #3
iTrader Rating: (0)
thanx
Old 04-17-2011, 10:45 AM   #4
chadalac1712
chadalac1712's Avatar
iTrader Rating: (0)
Send a message via AIM to chadalac1712
Very nice but why did it only make 423? Mine made 398 on 20 lbs. stock head no sleeves
edit: Didnt see the 600 on higher boost. Still I believe you could have a wayyyyy better tune on it and pull at least 30-40 hp more out of the 19lbs
chadalac1712 is offline   Reply With Quote
Old 04-17-2011, 11:15 AM   #5
jsheffield
Trial User
iTrader Rating: (0)
nice ek
jsheffield is offline   Reply With Quote
Old 04-17-2011, 03:46 PM   #6
iTrader Rating: (0)
well im sure i can make more power but really i don't need any more right now im sure if id keep it ill get a re tune and make 600 plus but i don't really need that for the street just saying maybe when its all just a drag car and thanks on the nice ek
Old 04-18-2011, 08:10 PM   #7
srt4mike
2005 Dodge SRT-4
srt4mike's Avatar
iTrader Rating: (0)
srt4mike srt4mike
Bump for viewing.
Originally Posted by Dr. DC2 View Post
srt4mike FTW
Originally Posted by R boy fresh View Post
srt4mike FTW
Originally Posted by LankorDie View Post
Srt4mike FTW
srt4mike is offline   Reply With Quote
Old 04-18-2011, 09:30 PM   #8
iTrader Rating: (0)
I was waiting on yea srt4mike and thanks on the bump
Old 04-18-2011, 10:11 PM   #9
Alexpbnj
iTrader Rating: (0)
bump for the sohc!
Alexpbnj is offline   Reply With Quote
Old 04-19-2011, 06:08 AM   #10
xkrazyxjbrkerx75
1996 Honda Civic
xkrazyxjbrkerx75's Avatar
iTrader Rating: (0)
bump! maybe i ask on how your wired up the gm map sensor?
Built z6- Thirsty for DAT B00ST
xkrazyxjbrkerx75 is offline   Reply With Quote
Old 04-22-2011, 06:30 PM   #11
iTrader Rating: (0)
bumping want to trade for k series and r u needing help just pm me
Old 04-24-2011, 02:16 PM   #12
iTrader Rating: (0)
I would like a k series hatch hit me up
Old 04-25-2011, 07:20 AM   #13
iTrader Rating: (0)
Bump
Old 04-25-2011, 07:35 AM   #14
s2ksupercharged
iTrader Rating: (0)
I have the same size intercooler... : ) BUMP!
s2ksupercharged is offline   Reply With Quote
Old 04-25-2011, 01:43 PM   #15
xkrazyxjbrkerx75
1996 Honda Civic
iTrader Rating: (0)
i already bought a 4 bar speedfactory map sensor, but thanks for the help! you should part out everything, u would make enough for a k swap.
18, built, civic, fully, honda, power, psi, series, trade, turbo, v8, z6
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
