Register Forgot Password?
Search
Notices
Old 01-12-2011, 04:09 PM   #1
airwalk07143
Garage is empty, add now
airwalk07143's Avatar
iTrader Rating: (0)
Default 2000 Integra Boosted 700+hp street car
2000 Acura Integra GSR
83,000 Miles
$8,500 firm (i will not go lower. This is a ridiculously low price!)
Located in Dubuque, Iowa
PLEASE EMAIL IF INTERESTED. BRAD.STEUER@GMAIL.COM
I ALSO HAVE MORE PICTURES I CAN SEND...
I was planning to have it ready for this season but I started a new job and i need to get a car I can travel in. Currently car is NOT running. It ONLY needs to be tuned (it just got a bigger fuel system in the spring. not touched since.) The motor is in perfect condition and ran very strong on 20psi! It ran high 10's on the same setup on 20psi. I also had the 10pt. cage installed this spring and is completed but needs to be certified. It shouldn't be a problem...it was S&W weldin cage with upgraded lower main hoop bar to make it fit current rules. Removeable door bars. Still very streetable. Or cut out the cage and have a normal interior (included) On 20 psi, its the insane. Car was built to run 35psi or so. At 35 psi you should be mid to high 700whp (some have made more). Easily a 9 sec street car! I built the fuel system with E85 in mind but it could be used with any gas. Car has been garage kept its whole life. I drive it all the time in the summer... its so much fun. I have owned it for 5 years or so and its only seen rain a few times.
Engine
Ls/Vtec (under 10,000 miles on build)
83mm benson sleeved block
gsr balanced and micropolished crank
Eagle Rods
83mm CP Pistons 9:1
New oem oil pump, waterpump, timing belt, ect. at time of rebuild
Commetic headgasket
ARP headstuds
SuperTech 0.5mm over sized valve springs
gsr cams
Moroso Oil pan
Edelbrock Intake manifold
Golden Eagle ls/vtec conversion kit
Custom Catch Can setup
Turbo Kit
Peakboost top mount b-series manifold (recently inspected by P.B. Not used since)
Peakboost 3in. downpipe
Peakboost 44mm dumptube
Precision 6765SP Turbo t3(1/2 season use. Never above 20psi)
Precision 46mm Wastegate (Installed in spring. Never seen boost)
Custom 3in. charge pipes
4-ply 3in couplers
T-bolt Clamps
31X12X4 bar and plate intercooler w/ custom single backdoor setup
S.S. oil feed
-10 a.n. Oil return
Fuel System
Sumped Tank (dual -8’s)
Dual Bosch 044’s (1 pump is brand new, other has 1 season use)
-8 an line from tank threw filters, then pumps, the “Y” together to filter and then -10 to fuel rail
STR anodized fuel rail
Bosch 1600cc injectors
Fuel Lab FPR (Brand NEW)
-8 an return line
Electronics
Hondata S300
Boost Solenoid for BBG
Sony Cd Player
Kicker speakers
Additonal Custom Sub encloser, kicker subs, kicker amps are not included but we could work something out. Cheap. (wont fit with the cage though )
Boost Gauge
PLX Wideband O2 (integrated into s300)
Oil pressure gauge (not installed yet)
M&W Pro 10 Ignition (T1 package)
omni 4 bar map sensor
Chassis
2000 Integra gsr Black
Great overall condition with a few minor door dings
Leather GSR seats (comes with rear seats but they wont work with roll cage)
10pt Roll cage (Finshed. Needs to be certified. Shouldn’t be a problem)
17in Buddy Club Wheels
Kumho Tires (good thread)
(2) 24X8X15 slicks with rims
Tokiko Illumina coilover setup
S.S brake lines
EBC Brake pads
Full-Race Traction bars
Avid Motor Mounts (stiff bushings)
Skunk2 Short throw and shift ****
Aluminum Radiator and Fan
Drive Train
C.C Twin disk (used season, mostly street, maybe 15 passes at track)
Stock gsr gearset with OBX LSD (laugh but it works perfect and hasn’t broke!)
Drive Shaft Shop 1000whp axles and hubs (stage 5 old version)
ARP extended wheelstuds
I am sure i am forgetting about some parts...
If you are interested please email me brad.steuer@gmail.com
That is the best way to contact me, since i am not on H-t as much as i used to be.
Click the image to open in full size.
On smaller 60mm turbo a few seasons ago. same motor
http://www.youtube.com/watch?v=7sQqY...layer_embedded
Arm Drop Live Same setup as today(minus cage, and 1600cc injectors) 20psi
http://www.youtube.com/watch?v=8wiuitlM4kw
2008: 00 DC2 ls/vtec E-85 450whp@20psi 311tq 11.2@130 (Street Car)
2009: 83mm ls/vtec pte6765 10.9 @137 20psi
airwalk07143 is offline   Reply With Quote
Old 01-13-2011, 05:07 AM   #2
RyanA
RyanA's Avatar
iTrader Rating: (0)
Default Re: 2000 Integra Boosted 700+hp street car
Wow. Good looking car. Interested in a commuter car as partial trade?
RyanA is offline   Reply With Quote
Old 01-13-2011, 03:03 PM   #3
airwalk07143
iTrader Rating: (0)
No. I just bought a van. Needed something with a lot of cargo space.
Old 01-13-2011, 08:18 PM   #4
airwalk07143
iTrader Rating: (0)
Old 01-13-2011, 09:23 PM   #5
MonarchClothing
Trial User
iTrader Rating: (0)
Send a message via AIM to MonarchClothing
Bump To The Top For A 2000 Integra Ls-Vtec Boosted 700+hp Street Car.
Lets See Some Engine Bay Pics..
$8,500 FIRM (I Will Not Go Lower. This Is A Ridiculously Low Price!)
MonarchClothing is offline   Reply With Quote
Old 01-14-2011, 06:35 PM   #6
srt4mike
2005 Dodge SRT-4
srt4mike's Avatar
iTrader Rating: (0)
srt4mike srt4mike
Bump for viewing.
Originally Posted by Dr. DC2 View Post
srt4mike FTW
Originally Posted by R boy fresh View Post
srt4mike FTW
Originally Posted by LankorDie View Post
Srt4mike FTW
srt4mike is offline   Reply With Quote
Old 01-14-2011, 08:14 PM   #7
Paste
Paste's Avatar
iTrader Rating: (0)
Send a message via Skype™ to Paste
You to can be in the medical marijuana business
Paste is offline   Reply With Quote
Old 01-14-2011, 08:51 PM   #8
mmcd
mmcd's Avatar
iTrader Rating: (0)
niceeeee glws
EM1 GSR Turbo 532hp- JK tuning
Em1 Build http://honda-tech.com/showthread.php...1#post46665922
mmcd is offline   Reply With Quote
Old 01-16-2011, 02:50 PM   #9
airwalk07143
iTrader Rating: (0)
Old 02-08-2011, 08:31 AM   #10
DA 4 Lyfe
DA 4 Lyfe's Avatar
iTrader Rating: (0)
Send a message via AIM to DA 4 Lyfe
bump.. nice car. What did it run?
1992 Integra DA
10.98 @ 128.12 (93 Pump Gas)
10.47 @ 140.77 (C16 Race Gas)
DA 4 Lyfe is offline   Reply With Quote
Old 02-08-2011, 10:43 AM   #11
Em1LuiSiR
Em1LuiSiR's Avatar
iTrader Rating: (0)
sweet car bump
Em1LuiSiR is offline   Reply With Quote
Old 02-08-2011, 02:06 PM   #12
wunfstgsr
wunfstgsr's Avatar
iTrader Rating: (0)
fn sick! good deal! you would spend $8000 on a 2000 gsr anyway and you get 700hp with it lol!
wunfstgsr is offline   Reply With Quote
Old 02-08-2011, 03:59 PM   #13
ebp 99 si
2000 Honda Civic
ebp 99 si's Avatar
iTrader Rating: (0)
Send a message via AIM to ebp 99 si
bump for a hell of a deal
05 evo8 built 2.4lr,buschur stage 3 head,aem water/meth,ets hta86 kit on 40psi
08 wrangler unlimited,7.5"lift,42x15 tsl's,lockers,etc
R.I.P Brian Arbogast(turbodcx)2/15/83-2/4/07
ebp 99 si is offline   Reply With Quote
10, 700, brad, car, gsr, honda, hose, hp, integra, mw, pro, radiator, steur, stiff, street
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
