-DC Sports catback exhaust, no cat, straight pipe welded where cat would bolt to. sounds good and not too loud. $230
Engine/Trans:
-D15b2 block(stock w/134,000 miles) $70
-D16y7 head(rebuilt 30,000 miles ago, Delta 272 cam, intake side ported) $300
Clean as hell. looks like it was rebuilt yesterday, lol. I have some ZEX valve springs to go in the head just not installed yet. Motor runs good just needs the valve springs installed and a tune would bring out the full potential
-D15B2 crank pulley w/AC, PS
-'90-91 Cable Si trans SOLD
Suspension/Brakes:
-Cable D-Series Shift linkage
-Speedo and Clutch Cable
-Rad/Heater Hoses
-Gas Tank
-Front Brake Lines
-Charcoal Canister with relay
-Ebrake Mechanism
-UnderDash Air Ducting(Drivers side)
Interior:
-Uncut Dash Harness
-Third Brake Light
-Stock Lower Sideskirts
-Mid-Rear fender trim peices(2)
-UnderDash Fush Panel and (B) Box Attached on back
Exterior/interior:
-Rear bumper
-Windshield Wipers
-Amber Corner and Bumper Lights SOLD
-Uncut 90-91 Si Radio/Underdash harness
-Clock
-Resistor Box
-Turn Signal and Windshield Washer Levers
-Fuse Box and Main Relay
-Locking Lug Nuts w/Key
-90-91 Driver Side Headlight Bucket
[b]ALSO FS:
-Short Ram intake(needs battery relocation in an EF) wrapped with header wrap. Newer filter(less than 2000 miles on it). Make an offer!
Bottom Head
-D16Y7 head 88,000 miles(no cam/cam gear, I have the rest of the parts)$50
Top Head
-D15b2 head 133,000 miles $60
-88-95 non-vtec Valve Covers(2) $20 each
-Wheel spacers New, never used 4x100(I need to measure the thickness) $40
-Autometer Oil Pressure Guage w/sending unit SOLD
-PG7 ECU(88-89 Manual trans) $30
-PR4 ECU(OBD0 Manual trans) $30
-Fog Lights(look similar to OEM EF foglights) $20
-Ebrake Cover(not sure what its from, integra maybe?) $10
90-91 Civic Hatchback Parts:
-Civic Sedan front mudflaps $20
-Trim Pieces Pictured(2) SOLD
-Civic hatchback clear corner lights $15
-Driverside Mirror(Red, some scratches) $20
-Drivers Door Handle/Lock $20
-d15b2 Upper Timing Cover Inner $10
-'88 D-Series Flywheel $20
-Flywheel Cover $15
-D16Z6 Cam(Stock) $20
-D16A6 Cam(stock) SOLD
-D16Y7 Cam Gear(not pictured) SOLD
-Part of Injector Harness w/clips, plastic cover $20
-Injector Resistor Box $20
-Door Speaker Cups $20
-B18 Crank Pulley $20
-DA Integra Lower Rad Hose $10
-DA Integra Motor Mount Inserts SOLD
-B&M Fuel Pressure Regaulator SOLD
