Go Back   Honda-Tech > Sponsor Marketplace > Performance
Old 08-18-2009, 04:44 PM   #1
RedlineMotive
H-T Premium Sponsor
RedlineMotive's Avatar
Default Honda and Acura Replacement Parts
Click here: Acura Replacement Parts | Honda Replacement Parts
We have thousands of in stock replacement parts for Honda and Acura. We have many parts from oil filters and timing belts, to axles and spark plugs.
Please check our catalog above for all of our parts, and if you don't see something, please ask and we will find out for you if we can get it.
Please use the yellow search box on the site to find your replacement parts.
Thanks Honda-Tech!
Mark
Redline Motive
Redline Motive - Redline9
RedlineMotive is offline   Reply With Quote
Old 08-19-2009, 07:55 AM   #2
RedlineMotive
H-T Premium Sponsor
Default Re: Honda and Acura Replacement Parts
Old 08-19-2009, 09:25 PM   #3
RedlineMotive
H-T Premium Sponsor
Acura Replacement Parts at Redline Motive!
A/C Clutch
A/C Clutch Solenoid
A/C Condenser
A/C Condenser Fan Motor
A/C Evaporator
A/C Expansion Valve
A/C Fan Relay
A/C Hose
A/C Pressure Switch
A/C Receiver Drier
A/C Relay
A/C Retrofit Kit
A/T Fluid
ABS Accumulator
ABS Relay
ABS Speed Sensor
ACC Cabin Filter
Acc. Belt Idler Pulley
Acc. Belt Tension Pulley
Acc. Belt Tensioner Assy
Accessory Drive Belt
Air Filter
Air Filter Perf. Kit
Air Filter Set
Alternator
Alternator Brush Assy.
Antenna Mast
Anti Rattle Spring
AT Filter
AT Filter Kit
AT Filter O-Ring
AT Overhaul Kit
AT Pan Gasket
AT Selector Cable
AT Solenoid
AT Speed Sensor
Aux. Fan Switch Seal
Auxiliary Fan Assembly
Auxiliary Fan Motor
Auxiliary Fan Switch
Auxiliary Shaft Seal
Axle Assembly
Axle Nut
Axle Seal
Back Up Light Switch
Bal Shaft Tension Spring
Balance Shaft Tensioner
Ball Joint
Ball Joint Boot
Battery Cable
Blower Motor
Book
Booster Check Valve
Brake Booster
Brake Caliper
Brake Disc
Brake Drum
Brake Hardware Kit
Brake Hose
Brake Master Cylinder
Brake Pad Set
Brake Pad Shim Set
Brake Pedal Pad
Brake Pedal Stop Pad
Brake Shoe Set
Bypass Hose
Cam Adjust Solenoid
Cam Follower
Cam Holder Seal
Cam Plug
Camshaft Position Sensor
Camshaft Seal
Cap and Rotor Kit
Carbon Cannister
Cat. Converter Gasket
Catalytic Converter
Clutch Cable
Clutch Disc
Clutch Hose
Clutch Kit
Clutch Master Cylinder
Clutch Pedal Pad
Clutch Pedal Stop Pad
Clutch Release Arm
Clutch Slave Cylinder
Coil Spring
Cold Air Intake Kit
Control Arm
Control Arm Bolt
Control Arm Bushing
Control Arm Bushing Kit
Converter Housing Seal
Crank Position Sensor
Crankcase Gasket Set
Crankshaft Pulley
Crankshaft Seal
CV Boot
CV Boot Clamp
CV Boot Clamp Kit
CV Boot Kit
CV Joint Kit
Cylinder Head Gasket
Cylinder Head Gasket Set
Cylinder Head Seal
Distributor Cap
Distributor Cap Gasket
Distributor Housing
Distributor O-Ring
Distributor Rotor
Distributor Seal
Drive Axle Seal
EGR Valve
EGR Valve Gasket
Engine Mount
Exhaust Bolt
Exhaust Flange Gasket
Exhaust Gasket
Exhaust Hanger
Exhaust Manifold
Exhaust Manifold Gasket
Exhaust Pipe
Exhaust Spring
Exhaust Valve
Flasher Relay
Flywheel
Flywheel Bolt
Fog Light
Fog Light Bulb
Fog Light Relay
Fuel Filter
Fuel Filter Seal
Fuel Inject Cushion Ring
Fuel Injection Perf Kit
Fuel Injection Relay
Fuel Injector
Fuel Injector Holder
Fuel Injector O-Ring
Fuel Injector Seal
Fuel Injector Seal Kit
Fuel Pressure Regulator
Fuel Pump
Fuel Pump Assembly
Fuel Pump Gasket
Fuel Pump Housing
Fuel Pump Relay
Fuel Screen
Fuel Tank Cap
Fuel Tank Drain Seal
Fuse
Hatch Strut
Hazard Light Relay
Header Pipe
Headlight Assembly
Headlight Bulb
Heater Core
Heater Hose
Heater Valve
Hood Strut
Idle Control Valve
Igniter
Igniter Heat Sink
Ignition Coil
Ignition Distributor
Ignition Lock Assembly
Ignition Switch
Ignition Wire Set
Input Shaft Seal
Intake Manifold Gasket
Intake Plenum Gasket
Intake Valve
Intermediate Pipe
Knock Sensor
Light Bulb
Lug Nut
MAP Sensor
Muffler
Multi Rib Belt
Neutral Safety Switch
Oil Cooler Seal
Oil Dipstick
Oil Drain Plug
Oil Drain Plug Gasket
Oil Filler Cap
Oil Filler Cap Gasket
Oil Filter
Oil Filter Stand Gasket
Oil Pan
Oil Pan Gasket
Oil Pressure Sender
Oil Pump
Oil Pump Gasket
Oxygen Sensor
Oxygen Sensor Gasket
P/S Hose O-Ring
P/S Pressure Hose
P/S Pump
P/S Seal
Park Light Assembly
Parking Brake Cable
Parking Brake Shoe
PCV Valve
PCV Valve Grommet
Pilot Bearing
Pilot Bushing
Pinion Seal
Piston
Piston Ring Set
Pressure Plate
Purge Valve Assembly
Rad. Drain Plug Gasket
Radiator
Radiator Cap
Radiator Drain Plug
Radiator Hose
Radius Rod Bushing
Rel. Brg. Retain. Spring
Relay
Release Bearing
Rod Bearing Set
Shift Rod Seal
Shock Absorber
Shock Bellows
Shock Bushing
Shock Mounting Kit
Short Ram Intake
Side Cover Gasket
Solenoid Gasket
Spark Plug
Spark Plug Seal
Speedometer Sensor
Speedometer Transmitter
Spool Valve Filter
Starter
Steering Rack
Steering Rack Boot
Steering Rack Boot Kit
Stop Light Switch
Strut Assembly
Strut Bearing
Strut Insert
Strut Mount
Strut Mounting Kit
Subframe Mount
Sunroof Relay
Suspension Kit
Suspension Knuckle Assy
Sway Bar Link
Sway Bar Link Bushing
Sway Bar Link Kit
T-Belt Tension Adjuster
T-Belt Tensioner Spring
T-Belt Tensioner Stopper
Tail Pipe Extension
Tailgate Strut
Thermostat
Thermostat Gasket
Thermostat Housing Cover
Thermostat Housing Gskt.
Tie Rod End
Tie Rod End Boot
Timing Belt
Timing Belt Idler
Timing Belt Kit
Timing Belt Tensioner
Timing Chain
Timing Cover Gasket
TPMS Sensor
Trailing Arm Bushing
Trans. Drain Plug Seal
Transmission Gasket
Transmission Mount
Turn Signal Assembly
Vacuum Valve
Valve Cover Gasket
Valve Cover Gasket Set
Valve Cover Nut
Valve Cover Seal Washer
Valve Guide
Valve Stem Seal
Water Pipe O-Ring
Water Pump
Water Pump Gasket
Water Pump Hsng O-Ring
Water Temp. Sensor
Water Temperature Sender
Wheel Bearing
Wheel Hub Assembly
Window Regulator
Windshield Wiper Motor
Wiper Blade
Wiper Blade Insert
Old 08-19-2009, 10:33 PM   #4
harnek
i have a1993 honda civic 1.5L 2 door DX, i need the bolt that protrudes through the valve cover for the nut to fasten on to
harnek is offline   Reply With Quote
Old 08-19-2009, 10:46 PM   #5
RedlineMotive
H-T Premium Sponsor
Sorry, we don't have this, might want to try the local honda dealer, as I don't think we've ever carried this part either.
Sorry about that!
Mark
Old 08-20-2009, 12:29 PM   #6
RedlineMotive
H-T Premium Sponsor
Thank you for your orders everyone! Check your emails for tracking numbers.
Old 08-20-2009, 05:34 PM   #7
harnek
Sorry about that!
Mark
thanks anyways
Old 08-20-2009, 05:38 PM   #8
harnek
what do you mean by bump?
Old 08-20-2009, 09:04 PM   #9
RedlineMotive
H-T Premium Sponsor
Honda A/C Clutch
Honda A/C Clutch Solenoid
Honda A/C Compressor
Honda A/C Condenser
Honda A/C Condenser Fan Motor
Honda A/C Evaporator
Honda A/C Expansion Valve
Honda A/C Fan Relay
Honda A/C Hose
Honda A/C Pressure Switch
Honda A/C Receiver Drier
Honda A/C Relay
Honda A/C Retrofit Kit
Honda A/T Fluid
Honda ABS Accumulator
Honda ABS Relay
Honda ABS Speed Sensor
Honda ACC Cabin Filter
Honda Acc. Belt Idler Pulley
Honda Acc. Belt Tension Pulley
Honda Acc. Belt Tensioner Assy
Honda Accessory Drive Belt
Honda Air Cleaner Nut
Honda Air Filter
Honda Air Filter Perf. Kit
Honda Air Mass Meter
Honda Air Temp. Sensor
Honda Alternator
Honda Alternator Bearing
Honda Alternator Brush Assy.
Honda Antenna
Honda Antenna Mast
Honda Anti Rattle Spring
Honda AT Cooling Pipe
Honda AT Filter
Honda AT Filter Kit
Honda AT Overhaul Kit
Honda AT Pan Gasket
Honda AT Selector Cable
Honda AT Solenoid
Honda AT Speed Sensor
Honda Aux. Fan Switch Seal
Honda Auxiliary Fan Assembly
Honda Auxiliary Fan Motor
Honda Auxiliary Fan Relay
Honda Auxiliary Fan Switch
Honda Auxiliary Shaft Seal
Honda Auxiliary Valve
Honda Auxiliary Valve O-Ring
Honda Auxiliary Valve Seal
Honda Axle Assembly
Honda Axle Nut
Honda Axle Seal
Honda Back Up Light Switch
Honda Bal Shaft Gear Case
Honda Bal Shaft Tension Spring
Honda Bal. Shaft Seal Retainer
Honda Balance Shaft Belt
Honda Balance Shaft Tensioner
Honda Ball Joint
Honda Ball Joint Boot
Honda Battery Cable
Honda Battery Hold Down Bolt
Honda Blower Motor
Honda Blower Motor Resistor
Honda Book
Honda Booster Check Valve
Honda Brake Adjusting Plug
Honda Brake Bleed Screw Cap
Honda Brake Booster
Honda Brake Caliper
Honda Brake Disc
Honda Brake Drum
Honda Brake Hardware Kit
Honda Brake Hose
Honda Brake Master Cylinder
Honda Brake Pad Set
Honda Brake Pad Shim Set
Honda Brake Pedal Pad
Honda Brake Pedal Stop Pad
Honda Brake Shoe Set
Honda Breather Hose
Honda Bypass Hose
Honda Cam Adjust Solenoid
Honda Cam Follower
Honda Cam Holder Seal
Honda Cam Plug
Honda Camshaft
Honda Camshaft Position Sensor
Honda Camshaft Seal
Honda Cap and Rotor Kit
Honda Carb. Heat Shield Gasket
Honda Carb. Insulator Gasket
Honda Carbon Cannister
Honda Carburetor Float Kit
Honda Carburetor Mount Flange
Honda Carburetor O-Ring
Honda Carburetor Repair Kit
Honda Cat. Converter Gasket
Honda Catalytic Converter
Honda Choke Diaphragm
Honda Clutch Cable
Honda Clutch Disc
Honda Clutch Hose
Honda Clutch Hose Connector
Honda Clutch Kit
Honda Clutch Master Cylinder
Honda Clutch Master Gasket
Honda Clutch Pedal Pad
Honda Clutch Pedal Stop Pad
Honda Clutch Slave Cylinder
Honda Coil Spring
Honda Cold Air Intake Kit
Honda Combination Switch
Honda Control Arm
Honda Control Arm Bolt
Honda Control Arm Bushing
Honda Control Arm Bushing Kit
Honda Control Arm Seal
Honda Control Valve Diaphragm
Honda Converter Housing Seal
Honda Cooling Fan Hub
Honda Crank Position Sensor
Honda Crankcase Gasket Set
Honda Crankshaft Pulley
Honda Crankshaft Seal
Honda CV Boot
Honda CV Boot Clamp
Honda CV Boot Clamp Kit
Honda CV Boot Kit
Honda CV Joint Kit
Honda Cylinder Head Bolt
Honda Cylinder Head Gasket
Honda Cylinder Head Gasket Set
Honda Cylinder Head Seal
Honda Diff. Pinion Bearing
Honda Distributor Bearing
Honda Distributor Cap
Honda Distributor Cap Gasket
Honda Distributor Housing
Honda Distributor O-Ring
Honda Distributor Rotor
Honda Distributor Seal
Honda Door Handle
Honda Door Lock Actuator
Honda Drier Desiccant Element
Honda Drive Axle Seal
Honda Driveshaft Support
Honda EGR Valve
Honda EGR Valve Gasket
Honda Engine Gasket Set
Honda Engine Mount
Honda Engine Torque Rod
Honda Exhaust Bolt
Honda Exhaust Flange Gasket
Honda Exhaust Gasket
Honda Exhaust Hanger
Honda Exhaust Manifold
Honda Exhaust Manifold Gasket
Honda Exhaust Spring
Honda Exhaust System Kit
Honda Exhaust Valve
Honda Fan Clutch
Honda Flasher Relay
Honda Flywheel
Honda Flywheel Bolt
Honda Fog Light Bulb
Honda Fog Light Relay
Honda Fuel Cutoff Relay
Honda Fuel Filter
Honda Fuel Filter Seal
Honda Fuel Inject Cushion Ring
Honda Fuel Injection Perf Kit
Honda Fuel Injection Relay
Honda Fuel Injector
Honda Fuel Injector Clip
Honda Fuel Injector Holder
Honda Fuel Injector O-Ring
Honda Fuel Injector Seal
Honda Fuel Injector Seal Kit
Honda Fuel Pressure Regulator
Honda Fuel Pump
Honda Fuel Pump Assembly
Honda Fuel Pump Gasket
Honda Fuel Pump Housing
Honda Fuel Pump Relay
Honda Fuel Screen
Honda Fuel Tank Cap
Honda Fuel Tank Drain Seal
Honda Fuse
Honda Fusible Link
Honda Hatch Strut
Honda Header Pipe
Honda Headlight Assembly
Honda Headlight Bulb
Honda Headlight Sealed Beam
Honda Headlight Switch
Honda Heater Control Unit
Honda Heater Core
Honda Heater Hose
Honda Heater Knob
Honda Heater Valve
Honda Hood Lock Assembly
Honda Hood Release Cable
Honda Hood Rod Clip
Honda Hood Rod Grommet
Honda Idle Control Valve
Honda Igniter
Honda Igniter Heat Sink
Honda Ignition Coil
Honda Ignition Coil Wire
Honda Ignition Distributor
Honda Ignition Lock Assembly
Honda Ignition Lock Cylinder
Honda Ignition Points
Honda Ignition Switch
Honda Ignition Wire Set
Honda Input Shaft Seal
Honda Intake Manifold Cover
Honda Intake Manifold Gasket
Honda Intake Plenum Gasket
Honda Intake Valve
Honda Interior Light Bulb
Honda Intermediate Pipe
Honda Intermediate Shaft Seal
Honda Knock Sensor
Honda Light Bulb
Honda Light Control Relay
Honda Lug Nut
Honda Main Bearing Set
Honda Manifold Gasket
Honda MAP Sensor
Honda Muffler
Honda Muffler Mount
Honda Multi Rib Belt
Honda Neutral Safety Switch
Honda Oil Cooler Seal
Honda Oil Dipstick
Honda Oil Drain Plug
Honda Oil Drain Plug Gasket
Honda Oil Filler Cap
Honda Oil Filler Cap Gasket
Honda Oil Filter
Honda Oil Filter Stand Gasket
Honda Oil Pan
Honda Oil Pan Gasket
Honda Oil Pressure Sender
Honda Oil Pump
Honda Oil Pump Gasket
Honda Oil Pump Seal
Honda Output Shaft Seal
Honda Oxygen Sensor
Honda Oxygen Sensor Gasket
Honda P/S Hose O-Ring
Honda P/S Pressure Hose
Honda P/S Pump
Honda P/S Pump Pulley
Honda P/S Seal
Honda Park Light Assembly
Honda Parking Brake Cable
Honda Parking Brake Shoe
Honda PCV Valve
Honda PCV Valve Grommet
Honda Pilot Bearing
Honda Pilot Bushing
Honda Pinion Seal
Honda Piston
Honda Piston Ring Set
Honda Pitman Arm
Honda Pre Heat Hose
Honda Pressure Plate
Honda Purge Valve Assembly
Honda Rad. Drain Plug Gasket
Honda Radiator
Honda Radiator Cap
Honda Radiator Drain Plug
Honda Radiator Hose
Honda Radius Rod Bushing
Honda Rel. Brg. Retain. Spring
Honda Relay
Honda Release Bearing
Honda Rod Bearing Set
Honda Shift Rod Seal
Honda Shock Absorber
Honda Shock Bellows
Honda Shock Bushing
Honda Shock Mounting Kit
Honda Short Ram Intake
Honda Solenoid Gasket
Honda Spark Plug
Honda Spark Plug Seal
Honda Speedometer Sensor
Honda Spool Valve Filter
Honda Starter
Honda Starter Contact Set
Honda Steering Rack
Honda Steering Rack Boot
Honda Steering Rack Boot Kit
Honda Stop Light Switch
Honda Strut Assembly
Honda Strut Bearing
Honda Strut Insert
Honda Strut Mount
Honda Stub Axle Seal
Honda Subframe Damper
Honda Subframe Mount
Honda Sunroof Relay
Honda Suspension Kit
Honda Suspension Knuckle Assy
Honda Sway Bar Link
Honda Sway Bar Link Bushing
Honda Sway Bar Link Kit
Honda T-Belt Tension Adjuster
Honda T-Belt Tensioner Spring
Honda T-Belt Tensioner Stopper
Honda Tail Light Housing
Honda Tail Pipe
Honda Tail Pipe Extension
Honda Tailgate Strut
Honda Thermostat
Honda Thermostat Gasket
Honda Thermostat Housing Cover
Honda Thermostat Housing Gskt.
Honda Throttle Body Gasket
Honda Throttle Body O-Ring
Honda Throttle Position Sensor
Honda Thrust Bearing
Honda Thrust Bearing Set
Honda Tie Rod End
Honda Tie Rod End Boot
Honda Timing Belt
Honda Timing Belt Idler
Honda Timing Belt Kit
Honda Timing Belt Tensioner
Honda Timing Chain
Honda Timing Cover
Honda Timing Cover Gasket
Honda Timing Cover Grommet
Honda Timing Cover Mount Nut
Honda Torque Rod Bushing
Honda TPMS Sensor
Honda Trailing Arm
Honda Trailing Arm Bushing
Honda Trans. Case Shaft Seal
Honda Trans. Drain Plug Seal
Honda Trans. Mount Buffer
Honda Transmission Gasket
Honda Transmission Mount
Honda Trunk Strut
Honda Turn Signal Assembly
Honda Turn Signal Lens
Honda Turn Signal Switch
Honda U Joint
Honda Vacuum Valve
Honda Valve Cover Gasket
Honda Valve Cover Gasket Set
Honda Valve Cover Seal Washer
Honda Valve Guide
Honda Valve Stem Seal
Honda Voltage Regulator
Honda Water Outlet Gasket
Honda Water Pipe O-Ring
Honda Water Pump
Honda Water Pump Gasket
Honda Water Temp. Sensor
Honda Water Temperature Sender
Honda Wheel Bearing
Honda Wheel Bearing Kit
Honda Wheel Cylinder
Honda Wheel Hub
Honda Wheel Hub Assembly
Honda Wheel Seal
Honda Window Channel
Honda Window Motor
Honda Window Regulator
Honda Window Switch
Honda Windshield Wiper Motor
Honda Wiper Blade
Honda Wiper Blade Insert
Honda Wiper Relay
Honda Wiring Harness
Old 08-21-2009, 04:30 PM   #10
RedlineMotive
H-T Premium Sponsor
Thanks for your orders today Honda-Tech! Have a good weekend!
Mark
Old 08-22-2009, 05:03 PM   #11
RedlineMotive
H-T Premium Sponsor
Hope everyone is having a good weekend!
Mark
Old 08-23-2009, 07:38 PM   #12
RedlineMotive
H-T Premium Sponsor
Thank you to everyone for your orders over this weekend!
Old 08-24-2009, 11:19 AM   #13
RedlineMotive
H-T Premium Sponsor
Thank you for your orders Honda-Tech!
Mark
Old 08-25-2009, 11:13 AM   #14
RedlineMotive
H-T Premium Sponsor
Bump for more parts in stock!
Old 08-26-2009, 02:34 PM   #15
RedlineMotive
H-T Premium Sponsor
All orders have shipped, thank you Honda-Tech!
Old 08-27-2009, 06:05 PM   #16
RedlineMotive
H-T Premium Sponsor
All PM's have been replied to.
Old 08-28-2009, 01:54 PM   #17
RedlineMotive
H-T Premium Sponsor
Thank you to everyone for your orders!
Old 08-29-2009, 12:18 PM   #18
RedlineMotive
H-T Premium Sponsor
Hope everyone is having a great weekend!
Mark
Old 08-30-2009, 09:52 PM   #19
RedlineMotive
H-T Premium Sponsor
Thank you for your orders this weekend Honda-Tech!
Mark
Old 08-31-2009, 04:07 PM   #20
RedlineMotive
H-T Premium Sponsor
All orders over the weekend have been shipped, thanks everyone!
Mark
Old 09-01-2009, 02:32 PM   #21
RedlineMotive
H-T Premium Sponsor
Bump for more inventory today!
Mark
Old 09-02-2009, 07:16 PM   #22
RedlineMotive
H-T Premium Sponsor
Thank you for all of your orders!
Mark
Old 09-03-2009, 03:26 PM   #23
RedlineMotive
H-T Premium Sponsor
Please send us any requests for anything you don't see on our website!
Mark
Old 09-04-2009, 01:43 PM   #24
RedlineMotive
H-T Premium Sponsor
Hope everyone is ready for a 3 day labor day weekend!
Mark
Old 09-06-2009, 10:40 AM   #25
RedlineMotive
H-T Premium Sponsor
Bump for a beautiful Sunday morning!
Mark
accura, acura, adjust, bleeder, cam, crx, distributor, honda, motive, odyssey, part, parts, replacement, ring, solenoid, switch, windshield, wiper
