Go Back   Honda-Tech > Regional Classifieds > Southeast (Sales)
Old 07-10-2009, 06:45 PM   #1
darrinbrewer
darrinbrewer's Avatar
Send a message via AIM to darrinbrewer
Default FS Turbo 92 civic SI hatch b18c1 garrett turbosmart wisco tial skunk2 tennessee
OPEN TO TRADES OF ALL KINDS OF STOCK VEHICLES (i'll take yours to sell, so you can get into this car easier!)
This is my 92 SI hatch I'll give the full story on the car, all the specs and parts I can think of!
VIN provided upon request, helps stop ebay thieves! no copy/pasteing my VIN into a ebay auction
Still has Power steering! no AC though. motor is fully built b18c1 with portflow head, Garrett 60-1 turbo, 780 injectors, 74mm tb (will detail down the page)
actual milage on odometer, in the 120k's (correct REAL miles of the car!)
Everything was built to be track worthy and streetable, ball joints, tie rod ends, ANYTHING showing wear got changed immediately
I spent over $13000 in parts, not including the car/shell itself that I traded a 4dr gsr for!
The $13k was my cost(not retail new), almost everything was bought brand new ,minus the turbosmart bov and tial wastegate.
I drove it daily all motor for a few years, then swapped pistons out and added all the turbo stuff. Nothing is cheap on this car, all top brands and parts.
Always been in the garage, never drove out into the rain, was caught in the rain and drove home, but never left the garage knowing it would rain.
BODY/Exterior:
JDM shit.com carbon hood, and a carbon duckbill wing
jdmshit.com GLASS black and clear headlights(hid looking cutoff line, really nice)
fogs do clear the ic piping
All amber corner lenses, amber oem depo foglight kit.
oem mud flaps
OEM Antennae delete.
paint was done about 4 years ago in Knoxville, the paint was 1981 Nissan rally red.
Last year I had the paint store use the eyeball, and thats what it said, they mixed up some and I painted a new bumper, and it matched perfect (hit a dead animal)
interior:
9.5/10 near mint stock SI interior
added the audio console(new from Honda), has oem rear speaker locations at the quarter panels, not back in the hatch area. all speakers are infinity.
BRAND NEW oem honda si floormats, ITR red stitch shift boot w/ctr copy shiftknob.
Cargo cover still intact and good
autometer 3pod pilar piece, whole piece, not a screw on.
All autometer carbon fiber ultralite gauges, boost/vac, elec. Oil press, and EGT
Greddy profec b dual boost controller
Suspension:
rear:
billstein Full bodied coil overs with neuspeed springs.
Rear lower Omnipower control arms
rear disk brakes (comes with brand new in box brembo rotors and honda pads)
omnipower camber kit
Front:
95 ex abs spindles and brakes(integra brakes)bought these for use with $1k DSS axles mention below)
arp extended studs,accord open ended lug nuts for the front
powdercoated the calipers red, has brembo rotors and honda pads)
omnipower adj. control arms, stainless brake lines
new tie rod ends, upper and lower ball joints new front wheel bearings
Transmission and related:
Drive Shaft shop 3.6 600HP axles and hub kit, AC35, paid $1040 for them
Trans is a 98 CTR (same as US spec ITR) has gearspeed carbon coated synchros
Quiafe Differential that came with new ring gear as well (oem honda gear)
I run gm synchromesh friction modified tranny fluid
Has gsr shift linkage with prothane inserts (i put these in all cars, they shift so good)
Clutch is a clutchmasters stage 5 strip clutch, thats actually streetable once your used to it. has a ACT streetlight flywheel.
Head and related:
my personal 94 gsr head, was sent to Mike laskey and he hand delivered it to Tom at portflow in CA and did the full race port and valvejob, and reassy and sent back.
Supertech Springs and retainers,
ferrea valves,
new ITR lost motion assy's,
new spring seats, and keepers.
Changed the rocker arms to low milage 25k ones at this time as well.
Skunk2 st2 cams with sk2 cam gears(never been moved from 0-0 yet)
head has been surfaced at portflow, but never cut down.
You will also get a set of ARP exhaust studs and nuts, as the stainless turbo mani broke 2 oem ones)
Skunk2 intake mani , and RPm service billet throttle body(72/74mm) mani was ported to match the tb) BDL fuel rail and stainless an fittings to connect to the fuel filter. AEM fuel pressure regulator and Marshall oil filled pressure gauge.
NGK blue plug wires with a msd blaster coil, run bkr7e11 itr plugs, gapped at about .026
Block:
94 gsr block, bored to 81.5mm (spec’d to match the forged pistons)
Has a 98 gsr crank
Eagle rods
Wiseco 10:1 pistons
OEM HONDA BEARINGS throughout
Z10 breather block plug
catch can mounted on firewall, has a drain cock for emptying (no vapor or liquids ever came back into the oil, its always been caught in the can and emptyied, returnless system.
Everything was measured at 2 different machine shops, and correct color bearings were installed. (checked them all after 5k miles of 9700rpm when it was all motor, all looked perfect, added the turbo setup at this point.
Turbo related:
Spoolin Performance ram horn,
tial 42 or 44mm wastegate,
custom made dump tube, jetcoated,
custom made 3” downpipe, jet coated (bumped the bottom on a speed bump),
garrett 60-1 .63ar with 360 thrust bearing(hot side jet coated black)
turbosmart bov
all 2.5inch aluminum charge pipes, welded at joints, not coupled
all couplers are the strong threaded ones
all t-bolt clamps
3” thermal research full exhaust
supposed garrett core intercooler, has 2.75 outlets
Turbo, dump, and downpipe have been jet-coated, crome color, black on the turbo
Electronics I can think of:
MSD digital 6 , ignition cut rev limiter with 2 step control
2 step wired to a push to talk button that plugs into the dash when at the track.
2.5BAR MAP
Chipped p28 with my crome setup running.
Currently has a techedge wideband, but I will provide a AEM to replace it, I have to keep the techedge and Honda 5 wire sensor that does with it.
Mid 90s accord resistor box for injectors.
Has fast-turbo’s vacuum mani, his turbo oil line kit, his fuel filter kit, and the oil pressure sending unit relocator kit. If I needed it, it cam from Stan@fast-turbo first.
Any part Mike Laskey sold, I went to him 1st for that. Laskey can verify the headwork I speak of as well.
The motor was on 11:1 pistons for a year, then I swapped to 10:1’s and turbo’d it. About 5k miles all motor, then in went the new pistons, and about another 6k since then.
I tuned it conservative with less timing and runs 11.0 to 11.4 AFR under boost.
Car stayed locked up in the garage, just drove on nice days. Bought a new house and need to get more of a practical car.
Nothing has been skipped, its 100% in every way.
The ONLY Trades I will consider:
newer RSX/TSX
350z g35
With over $18,000 or so in it(not including the shell itself), I’m asking $10,000
Located in ne Tennessee tri cities area (2 hours east of knox, 1 hour north of Asheville)
If you view and like what you see, please leave a reply!
here's a video of the 1st night at the track on my all motor baby 20" slicks (ran out of gear they were so short)
List of parts I kept up with and what I paid
dss axles $1,040.00
portflow headwork labor $1,000.00
garrett 60-1 turbo $650.00
quaife diff $600.00
spoolin performance mani $566.00
skunk2 stage2 cams $515.00
wiseco pistons $435.00
ferrea valves $337.00
Eagle Rods $312.00
3" thermal research exhaust $310.00
clutchmasters stage 5 clutch $395.00
supertech valve springs $290.00
msd digital6 $285.00
ITR LMAS $265.00
act street lite flywheel $219.00
engine machine work /balance $219.00
injectors 780 precision $200.00
tial 44mm wastegate$200.00
turbosmart bov $200.00
autometer egt $158.00
omnipower front camber kit $155.00
greddy profec B $150.00
intercooler $150.00
bdl fuel rail and fittings $140.00
brakes $140.00
oil pump, rear seal, strainer gasket $135.00
down pipe coating $125.00
arp head studs $114.00
downpipe parts $111.00
gsr crank from a 98' $111.00
omni rear camber kit $110.00
wheel bearings $110.00
honda bearings $105.00
walbro 255hp fuel pump $114.00
black audio console for civic $100.00
oil catch can $100.00
powder coat calipers $100.00
stainless brake lines $100.00
gsr water pump $96.00
radiator $95.00
rod bearings $90.00
cometic hg $85.00
carbon synchro's $83.00
exhaust studs $83.00
t bolt-couplers $80.00
jazz can $76.00
tie rod ends $70.00
window molding $68.00
boost guage $65.00
2 u bends ic pipe $64.00
msd cap $64.00
mud flaps $60.00
2 2.5" elbows $50.00
floor mats $50.00
oil line kit stan $50.00
slim fan? $50.00
weld wire $50.00
t-belt $46.00
3" flange and u bend $45.00
alignment $45.00
dumptube $40.00
roger welds $40.00
vac mani $35.00
flex pipe $34.00
z10 breather plug $31.00
grub screws and flange $30.00
gaskets $28.00
4 bolt turbo flange $25.00
map sensor $24.00
valve cover gasket and grommets $24.00
flange $23.00
IM gasket/tb gasket $20.00
oil pan gasket $20.00
tial spring $20.00
shifter bushings $17.00
oil cam seals $14.00
EX gasket $13.00
10an cap $11.00
barb fitting and hose $10.00
IM gasket $10.00
stainless rod $10.00
valve stem seals $10.00
barb fitting and hose $4.00
autometer vac/boost guage $30
autometer elec oil press guage $50
list doesn’t include (or may have overlooked)
complete 95 ex abs spindles had to have for DSS axles
bilstein full bodied coilovers
new brembo rotors and honda pads front
NIB brembo rotors/pads for rear
you get these wheels and tires
2 si wheels with 80% left falken azenis
2 si wheels have 30-40% falken azenis
its went 11.7s @117 on 20" slicks spinning a lot on 10psi
it went 12.2 @125 on azenis
its last track day was 17psi but I couldn’t get the power to hold
its been tuned by me on crome,
wideband/EGT always been present
interior it near mint..new oem floor mats, only dirt/grass is in rear area from slick transport
here's extra parts i have that can be bought really cheap by the buyer of the car
NIB spoolin performace powdercoated traction bar setup, was $250 new
NIB spoolin performace aluminum catch can (was $89 new)
NEW PICS ADDED!! 11-13-09
vouch's : look at my BIO, all my vouches are there, also on ebay, 300+ 100% FEEDBACK
gsr ECU $50+ship
[url=http://www.hondamarketplace.com/zerothread?id=2321444[/url]
darrinbrewer is offline   Reply With Quote
Old 07-11-2009, 07:10 AM   #2
darrinbrewer
Default Re: FS Turbo 92 civic SI hatch b18c1 garrett turbosmart wisco tial skunk2 tennessee
nice setup here
gsr ECU $50+ship
Old 07-11-2009, 09:49 AM   #3
JDMvirginNC
JDMvirginNC's Avatar
Send a message via AIM to JDMvirginNC
Really nice Si bro! GLWS!
333whp NONvtec turbo d16
VOUCHES: ctr status, KingOfQB, Juggernaut 2, csulliva, KevronsEG, CrxHsv, crxpwr1, dellude, 91crx_829
JDMvirginNC is offline   Reply With Quote
Old 07-11-2009, 03:45 PM   #4
illfaded
illfaded's Avatar
ALOT of info. on your car. Buyer should be extremely pleased.
illfaded is offline   Reply With Quote
Old 07-11-2009, 06:33 PM   #5
Jimmy
Moderator
Jimmy's Avatar
I will personally vouch for this car and how clean it is. This car was my first ever vehicle and it was in immaculate shape when i purchased it as well as my constantly cleaning it and it looks like you have taken great care of it darrin and did everything i wanted to do to it, but didn't have the funds to do at the time.
If i had a buyer for my integra I would pick this thing up right now. I see it still has my honda-tech sticker i put on it years ago.
GLWS.
/// 1994 Integra RS-T | 2002 cbr f4i
Jimmy is offline   Reply With Quote
Old 07-12-2009, 03:51 PM   #6
Zish06
Zish06's Avatar
bump for a CLEAN ASS CAR and very very fast gets me giddy like a school girl everytime i ride in it, glws darrin
Zish06 is offline   Reply With Quote
Old 07-13-2009, 10:57 AM   #7
darrinbrewer
i also have a huge stack of reciepts that the buyer can have as well
gsr ECU $50+ship
Old 07-14-2009, 07:58 PM   #8
Rdriver
1997 Honda Civic
My Garage
Rdriver's Avatar
Send a message via AIM to Rdriver
Bump....
My EK pics
http://www.honda-tech.com/zero...age=1
Rdriver is offline   Reply With Quote
Old 07-15-2009, 08:40 AM   #9
darrinbrewer
thanks for the comments!
will trade for something of equal value, something i can sell easier, and get you into this car!
gsr ECU $50+ship
Old 07-18-2009, 06:12 AM   #10
darrinbrewer
open to trades!
gsr ECU $50+ship
Old 07-18-2009, 07:25 AM   #11
dbb95ex
dbb95ex's Avatar
Bump for awesome car! Wish I had some cash.
dbb95ex is offline   Reply With Quote
Old 07-18-2009, 08:08 AM   #12
coquieg6
2003 Honda Ridgeline
My Garage
coquieg6's Avatar
hey whats the tire size on you si wheels??
SpoonSports
coquieg6 is offline   Reply With Quote
Old 07-19-2009, 06:23 AM   #13
darrinbrewer
205-50-15 falken azenis
gsr ECU $50+ship
Old 07-19-2009, 04:01 PM   #14
darrinbrewer
open to trades!
gsr ECU $50+ship
Old 07-19-2009, 09:24 PM   #15
Officer
Officer's Avatar
Absolutely Love it, GLWS...TTT
According to the ancient Sumerian text, the oldest version of the bible,
there is a tenth planet in our solar system called Nibiru where a highly advanced human-like civilization lives. Their jiu jitsu must be off the hook. -Eddie Bravo-
Officer is offline   Reply With Quote
Old 07-29-2009, 02:42 PM   #16
darrinbrewer
thank you
gsr ECU $50+ship
Old 08-04-2009, 06:31 PM   #17
darrinbrewer
any trades?
gsr ECU $50+ship
Old 08-05-2009, 06:05 AM   #18
Rdriver
1997 Honda Civic
My Garage
Rdriver's Avatar
Originally Posted by darrinbrewer View Post
any trades?
What about a turbo EK, an EM1 si or a Nissan Versa?
My EK pics
Old 08-05-2009, 12:51 PM   #19
badazzlaosboy
New User
badazzlaosboy's Avatar
Send a message via AIM to badazzlaosboy
SICK hatch glws!!
badazzlaosboy is offline   Reply With Quote
Old 08-09-2009, 10:21 AM   #20
Rdriver
1997 Honda Civic
My Garage
Rdriver's Avatar
Up
My EK pics
Old 08-15-2009, 06:23 PM   #21
Rdriver
1997 Honda Civic
My Garage
Rdriver's Avatar
Originally Posted by Rdriver View Post
Up
Again. Im sent.
My EK pics
Old 08-18-2009, 03:57 AM   #22
crowe
crowe's Avatar
bump for bristol glws
crowe is offline   Reply With Quote
Old 08-19-2009, 04:57 PM   #23
darrinbrewer
edited, i accidentally listed a 65mm in the mod list ( i had that when it was all motor, has the bigger rpm service TB now)
gsr ECU $50+ship
Old 08-23-2009, 03:35 PM   #24
darrinbrewer
price lowered
gsr ECU $50+ship
Old 08-24-2009, 02:18 PM   #25
Rdriver
1997 Honda Civic
My Garage
Rdriver's Avatar
TTT
My EK pics
13, b18c1, bdl, block, fuel, garrett, kit, lenoso, nc, port, rail, short, size, skunk, spring, synchro, t3
