Go Back   Honda-Tech > Sponsor Marketplace > Wheels, Tires, Brakes, and Suspension
Old 02-17-2009, 10:36 AM   #26
hector85
hector85's Avatar
Send a message via AIM to hector85
Default Re: Modern Honda: Your Source for PIC Performance Coilovers!
Originally Posted by Jason.H. View Post
bump for awesome products. ive used pic select in 12k 14k for 2 years now on my 2000 civic. they have seen alot of track time at vir, cmp, and roebling road. and i daily drive it on the street. the guys that own the company (allen and tim i believe) are super easy to deal with and are great guys that are always out at the track days for nasa with honda challenge. go to picperformance.com to check the specs on their stuff.
nice! I have ad set of selects 10k-8k for about two an half years. i haven't had any issues with them either, and they're on a daily car. Although the threaded section and the springs themselves have developed some rust. It's nothing too crazy, but they claim that they don't rust. I usally try to spray PB blaster on them to keep them from ceasing. Is there any rust on yours?
Vouches
midwesta,Integ4Life,MrPotatoeHead,SuperSteve737,bo osted96midorihatch,HondaEJ,7TOMEK,Krazykoreancrx,9 2b16si,voltronmas13,traitorzxiong, sol_1,bokals,paopao,AFTERZERO
hector85 is offline   Reply With Quote
Old 02-18-2009, 10:38 AM   #27
hector85
hector85's Avatar
hmmm.. interesting! lovely car btw!
PIC's are manufacture here in Illinois, in Naiperville
Vouches
Old 02-19-2009, 03:10 PM   #28
ww evo ix
ww evo ix's Avatar
thanks Adam
looking forward to my order, and a review once installed
For SALE 99-00 Front end Conversion ---->> http://hondamarketplace.com/showthread.php?t=2568319
ww evo ix is offline   Reply With Quote
Old 02-19-2009, 04:37 PM   #29
modernhonda
H-T Basic Sponsor
modernhonda's Avatar
Send a message via AIM to modernhonda
Thanks willy!
www.modernhonda.com GUARANTEED THE BEST PRICES, WE WILL NOT BE BEAT! www.maperformance.com
AIM: JordanMAP | P: 1.888.MAPerformance
modernhonda is offline   Reply With Quote
Old 02-20-2009, 04:32 PM   #30
modernhonda
H-T Basic Sponsor
It's the weekend again!
Old 02-21-2009, 01:07 PM   #31
JDMDC4life
JDMDC4life's Avatar
Send a message via AIM to JDMDC4life
how much for PIC selects R3 12kf 14kr coilovers with spherical LCA's shipped to 60020
JDMDC4life is offline   Reply With Quote
Old 02-23-2009, 04:14 PM   #32
modernhonda
H-T Basic Sponsor
You have pm!
Old 02-24-2009, 12:28 AM   #33
TheJunBuilt
TheJunBuilt's Avatar
pm sent ..
www.Dynotuned.com
Tuning Available: AEM, Hondata, Uberdata and many more
d.t.p turbo kits! (608-663-dyno) mikejones sent you!
TheJunBuilt is offline   Reply With Quote
Old 02-24-2009, 08:24 AM   #34
modernhonda
H-T Basic Sponsor
Bump!
Old 02-24-2009, 12:14 PM   #35
ChameleonDesignz
ChameleonDesignz's Avatar
Send a message via ICQ to ChameleonDesignz
Originally Posted by modernhonda View Post
Hey guys,
Decided to put a post up with the main focus on PIC Performance Coilovers and other Suspension Products. We have had a lot of interest in these coilovers the past couple of months, and want to offer them to you at a special price! Check out the applications/products below, and let us know what you need!
Coilovers
APEX: (88-00 Civic / 90-01 Integra)
~ Multiple spring rate combinations available (see Option Box on right for choices) to suit various driving styles and applications
~ Dampers have undergone numerous shock dyno tests to determine ideal valving for each application, delivering superb damping characteristics.
~ Dyno and track-tested damping levels, specifically designed and matched to each application and spring rates.
~ Fully Independent height & preload adjustments.
~ 3 stage anodized coating on shock body provides extra weatherproofing and protection against oxidation.
~ Viton sealed pistons protect vital moving parts against friction and wear, even against extremely high temperatures and oil.
~ Nitrogen gas-filled lower portion, with free-floating secondary valve offers more flexible low and high speed damping.
~ 46mm piston diameter and 54mm shock body provide improved damping capabilities and heat dissipation. 89-91 Civic/90-93 Integra/88-91 CRX: 42mm rear piston/50mm rear shock body
~ Two 6061-T6 aluminum alloy collars hold spring and lower mount in place and an additional third collar provides added support to the spring perch.
~ 6061-T6 aluminum alloy is used for both top and bottom mounts, coated in a fade and chip-resistant paint.
89-91 Civic/90-93 Integra/88-91 CRX: Uses modified, raised topmounts combined with shortened lower mounts in the fronts to achieve a large range of height adjustment, while retaining shock travel.
~ 240 hours of salt spray test on steel shock body shows no signs of fading or rust.
SELECT: (88-00 Civic / 90-01 Integra / WRX STi / EVO)
~ 8 levels of rebound adjustable damping to suit a variety of road and track conditions.
~ Patent-pending adjustment mechanism ensures clearly seperated damping levels marked by an identifiable click at each setting, making for easily repeatable settings every time. Needle-valve design ensures no internal damage due to over-turning of the adjustment mechanism.
~ 46mm piston diameter and 54mm shock body provide improved damping capabilities and heat dissipation. 89-91 Civic: 42mm rear piston/50mm rear shock body
89-91 Civic: Uses modified, raised topmounts combined with shortened lower mounts in the fronts to achieve a large range of height adjustment, while retaining shock travel.
Final Drives:
~ Final Drive set (ring and pinion) for Honda and Acura applications.
~ Reduced final ratio for improved acceleration and road-course gearing.
~ Available applications:
B16A/1/2/3/4: 4.05, 4.79, 4.93
B18C/1/5: 4.05, 4.79, 4.93
D15B, D16A: 4.5, 4.7, 4.9
K20A/2/3: 5.84, 6.3
~ Note 1 (for USDM Type-R Owners):
Final Drive sets for the USDM ITR Transmissions utilize the stock First Gear, Needle Bearing, and Distance Collar. No need to purchase JDM ITR First Gear, Distance, Needle Bearing or Distance Collar.
~ Note 2:
B18C applications will not fit Y80/S80 from B16B or JDM B18C 96-Spec Integra Type R / SiR-G, or any 14-bolt differentials.
Lower Control Arms:
~ PIC's Race-Ready LCA, based on existing modular lower control arm design, utilizing proprietary spherical bearings and a polyurethane blend both developed, designed, and manufactured in-house by PIC Performance. Spherical bearings eliminate all flex in the bushing locations, providing exact location of the rear lower control arms, necessary when used in race conditions with other high performance suspension components like our PIC Apex and Select coilovers.
~ Forged 6061-T6 aluminum arm, with aerospace-grade spherical bearings replacing the outboard and inboard hard-rubber bushings, and polyurethane replacing the center shock-mount bushing to eliminate deflection (unwanted camber and toe changes during suspension travel)
~ Light weight with a high tensile strength (31.5kg/mm2), the enhanced version of our normal lower control arms have been track-tested and race proven, race after race, during the 2006 NASA Season.
~ Replaceable bushings. Modular design eliminates the need to replace the whole unit when only the bushings are to be changed.
Available with OEM replaceable bushings as well.
Bushing Kits
~ Complete set of replacement Hard Rubber Bushings for Civics and Integras.
~ Developed in conjunction with Suja 1 Motoring, these bushing kits were designed with high performance use in mind. Deflection in the suspension is dramatically reduced, resulting in more precise steering response and a more stable car.
~ Uprated hardness rating (20-40% stiffer than stock) ensures greater longevity when paired with stiffer shocks and springs, stickier tires and the demands of competition use.
~ Each set comes with every bushing needed to entirely replace your current bushing set: front and rear upper control arms, front and rear lower control arms, rear trailing arm and rear compensator arm.
1988-1991 Honda Civic and CRX
1990-1993 Acura Integra
1992-1995 Honda Civic and Del Sol
1994-2001 Acura Integra
1996-2000 Honda Civic
~ Not all bushings will fit the following applications:
90-93 Acura Integra (all models - rear trailing arm bushing not compatible)
97-01 Acura Integra Type-R (rear LCA bushings not compatible)
88 Honda Civic (rear LCA bushings not compatible)
99-00 Civic non-Si models (front LCA bushings not compatible)
PM | EMAIL | CALL | AIM | FOR BEST PRICING!
Phone: 763-545-3800 Ask For Adam
E-mail: Adam@maperformance.com
Aim: AdamatMap
how much for thse shipped to puerto rico 00773?
Visit My EBAY Store! Headers (B,H&K Series) + more!
http://stores.ebay.com/Honda-Specialties
Integra 96 | 260whp 173tq | 1/4 Mile Time: 11.9@113mph | Neoh2ning
ChameleonDesignz is offline   Reply With Quote
Old 03-09-2009, 06:41 PM   #36
Decaf
Decaf's Avatar
Send a message via AIM to Decaf
price for coilovers for 94 ej1 shiped 10510?
Decaf is offline   Reply With Quote
Old 03-11-2009, 11:48 PM   #37
EK Josh
1997 Acura Integra
EK Josh's Avatar
Can you please PM me a price for the PIC Select P2 (10kF/8kR) coilovers as well as the price for the PIC Apex P2 (10kF/8kR) coilovers for a 1997 Integra GSR shipped to 92840. Thank you in advance.
||'97 Integra GS-R||
EK Josh is offline   Reply With Quote
Old 03-13-2009, 12:12 AM   #38
jadegreendc5
jadegreendc5's Avatar
Send a message via AIM to jadegreendc5
you have pm
jadegreendc5 is offline   Reply With Quote
Old 03-13-2009, 07:00 AM   #39
black94sol
black94sol's Avatar
Send a message via AIM to black94sol Send a message via MSN to black94sol Send a message via Yahoo to black94sol
ygpm...reply soon
I my Honda | dSoc #29
95 EH6
TruForm.
black94sol is offline   Reply With Quote
Old 03-18-2009, 02:17 PM   #40
B16B_coupe
Senior Member
B16B_coupe's Avatar
Send a message via AIM to B16B_coupe
Hit me up on a price on Pic for 96-00 civic
Selects please
Mugen mf8s,ek9 cluster,takata 5pt harness for sale. pm me for details
Function>Form
flickr Dont shop at zerolift in cini OHIO
B16B_coupe is offline   Reply With Quote
Old 03-18-2009, 07:59 PM   #41
SiR-G DC
SiR-G DC's Avatar
Send a message via AIM to SiR-G DC
How much shipped to 33618. For the PIC Select and Apex?
My 01' SSM DC Build Thread.
Originally Posted by JDMFreak_DC2 View Post
your teg is by far one of the cleanest and tastefully modded LS's I've seen period. Sometimes a simple, clean car like yours stands out beyond the rest
SiR-G DC is offline   Reply With Quote
Old 03-19-2009, 12:47 AM   #42
SkankyEJ7
SkankyEJ7's Avatar
I love my selects
2003 RSX type s
1998 civic lx
wēk´sôs ĭn'dustrēz
SkankyEJ7 is offline   Reply With Quote
Old 03-21-2009, 03:34 PM   #43
klectic
can the p1's or p2's lower approx 3" - 3.5" on a eg coupe? just recently got recommended these and am doing some research lol
_generatioNEXT
klectic is offline   Reply With Quote
Old 03-22-2009, 07:03 PM   #44
topdog
topdog's Avatar
pm sent
my vouches that I sold to: ff_terror, BlueIntegraBoy, jdm civic 2000, mikkellucci, Epoch, rexman, KLOW91, 94rs-turbo, h22-tech, nate_2k5, MIGS, PA Matt, clemsonhatch
My For sale Thread MAD STUFF http://www.hondamarketplace.com/show....php?t=2563265
topdog is offline   Reply With Quote
Old 03-22-2009, 09:17 PM   #45
b18c93EG6
New User
b18c93EG6's Avatar
Send a message via AIM to b18c93EG6
Pm price for a set of selects (8k/6k)for a 92 bubble
AIM: kienkontrami29
<U>Phantom Grey Pearl/Granada Black Pearl EG6</U> http://images.honda-tech.com/set1/smile/emsmileo.gif http://is.rely.net/1-92-30009-l-tEzP...BTGi0jOCgA.gif
b18c93EG6 is offline   Reply With Quote
Old 03-24-2009, 11:44 PM   #46
GetawayInMoscow
B*a*n*n*e*d
Send a message via AIM to GetawayInMoscow
PM me price for 00 EX
GetawayInMoscow is offline   Reply With Quote
Old 03-25-2009, 10:07 AM   #47
joe505
how much for coilovers for 99 civic si
to 10705
joe505 is offline   Reply With Quote
Old 03-30-2009, 07:14 PM   #48
sol_1
sol_1's Avatar
price on pic select for a 96-00 civic shipped?
Shit happen when you party naked!
sol_1 is offline   Reply With Quote
Old 03-31-2009, 09:28 AM   #49
buff1110
buff1110's Avatar
Send a message via AIM to buff1110
can you send me a price on pic for 93 del sol si please
93 del sol si
2002 toyota tacoma trd
buff1110 is offline   Reply With Quote
Old 04-02-2009, 11:36 PM   #50
lowside67
Can you PM me a price for a set of PIC Selects for a 95 CX Hatch? Also, can you confirm what spring rate choices are available?
lowside67 is offline   Reply With Quote
1z, adjusting, bushings, coil, coilovers, crx, cuda, front, number, overs, performance, pic, picperformance, select, tracking, type
