Go Back   Honda-Tech > Sponsor Marketplace > Wheels, Tires, Brakes, and Suspension
Old 01-14-2009, 07:16 AM   #1
modernhonda
H-T Basic Sponsor
modernhonda's Avatar
Send a message via AIM to modernhonda
Icon7 Modern Honda: Your Source for PIC Performance Coilovers!
Hey guys,
Decided to put a post up with the main focus on PIC Performance Coilovers and other Suspension Products. We have had a lot of interest in these coilovers the past couple of months, and want to offer them to you at a special price! Check out the applications/products below, and let us know what you need!
Coilovers
APEX: (88-00 Civic / 90-01 Integra)
~ Multiple spring rate combinations available (see Option Box on right for choices) to suit various driving styles and applications
~ Dampers have undergone numerous shock dyno tests to determine ideal valving for each application, delivering superb damping characteristics.
~ Dyno and track-tested damping levels, specifically designed and matched to each application and spring rates.
~ Fully Independent height & preload adjustments.
~ 3 stage anodized coating on shock body provides extra weatherproofing and protection against oxidation.
~ Viton sealed pistons protect vital moving parts against friction and wear, even against extremely high temperatures and oil.
~ Nitrogen gas-filled lower portion, with free-floating secondary valve offers more flexible low and high speed damping.
~ 46mm piston diameter and 54mm shock body provide improved damping capabilities and heat dissipation. 89-91 Civic/90-93 Integra/88-91 CRX: 42mm rear piston/50mm rear shock body
~ Two 6061-T6 aluminum alloy collars hold spring and lower mount in place and an additional third collar provides added support to the spring perch.
~ 6061-T6 aluminum alloy is used for both top and bottom mounts, coated in a fade and chip-resistant paint.
89-91 Civic/90-93 Integra/88-91 CRX: Uses modified, raised topmounts combined with shortened lower mounts in the fronts to achieve a large range of height adjustment, while retaining shock travel.
~ 240 hours of salt spray test on steel shock body shows no signs of fading or rust.
SELECT: (88-00 Civic / 90-01 Integra / WRX STi / EVO)
~ 8 levels of rebound adjustable damping to suit a variety of road and track conditions.
~ Patent-pending adjustment mechanism ensures clearly seperated damping levels marked by an identifiable click at each setting, making for easily repeatable settings every time. Needle-valve design ensures no internal damage due to over-turning of the adjustment mechanism.
~ 46mm piston diameter and 54mm shock body provide improved damping capabilities and heat dissipation. 89-91 Civic: 42mm rear piston/50mm rear shock body
89-91 Civic: Uses modified, raised topmounts combined with shortened lower mounts in the fronts to achieve a large range of height adjustment, while retaining shock travel.
Final Drives:
~ Final Drive set (ring and pinion) for Honda and Acura applications.
~ Reduced final ratio for improved acceleration and road-course gearing.
~ Available applications:
B16A/1/2/3/4: 4.05, 4.79, 4.93
B18C/1/5: 4.05, 4.79, 4.93
D15B, D16A: 4.5, 4.7, 4.9
K20A/2/3: 5.84, 6.3
[b][i]~ Note 1 (for USDM Type-R Owners):
Final Drive sets for the USDM ITR Transmissions utilize the stock First Gear, Needle Bearing, and Distance Collar. No need to purchase JDM ITR First Gear, Distance, Needle Bearing or Distance Collar.
~ Note 2:
B18C applications will not fit Y80/S80 from B16B or JDM B18C 96-Spec Integra Type R / SiR-G, or any 14-bolt differentials.
Bushing Kits
~ Complete set of replacement Hard Rubber Bushings for Civics and Integras.
~ Developed in conjunction with Suja 1 Motoring, these bushing kits were designed with high performance use in mind. Deflection in the suspension is dramatically reduced, resulting in more precise steering response and a more stable car.
~ Uprated hardness rating (20-40% stiffer than stock) ensures greater longevity when paired with stiffer shocks and springs, stickier tires and the demands of competition use.
~ Each set comes with every bushing needed to entirely replace your current bushing set: front and rear upper control arms, front and rear lower control arms, rear trailing arm and rear compensator arm.
1988-1991 Honda Civic and CRX
1990-1993 Acura Integra
1992-1995 Honda Civic and Del Sol
1994-2001 Acura Integra
1996-2000 Honda Civic
~ Not all bushings will fit the following applications:
90-93 Acura Integra (all models - rear trailing arm bushing not compatible)
97-01 Acura Integra Type-R (rear LCA bushings not compatible)
88 Honda Civic (rear LCA bushings not compatible)
99-00 Civic non-Si models (front LCA bushings not compatible)
PM | EMAIL | CALL | AIM | FOR BEST PRICING!
Phone: 1.888.MAPerformance Ask For Jordan
E-mail: Jordan@maperformance.com
Aim: JordanMAP
www.modernhonda.com GUARANTEED THE BEST PRICES, WE WILL NOT BE BEAT! www.maperformance.com
AIM: JordanMAP | P: 1.888.MAPerformance
modernhonda is offline   Reply With Quote
Old 01-14-2009, 08:22 AM   #2
RHD_H2b_EG6_Coupe
1993 Honda Civic
Send a message via MSN to RHD_H2b_EG6_Coupe
Default Re: Modern Honda: Your Source for PIC Performance Coilovers!
Ordered me a set lot cheaper then could find anywhere else
76 Hatch-Still looking for parts/94 EG T60 LS 18-Blew ....opps/93 EG GT30 B20 -Motor sold and parts car/
93 EG H2B...waiting to be built after deployment
RHD_H2b_EG6_Coupe is offline   Reply With Quote
Old 01-14-2009, 04:31 PM   #3
deemack79
deemack79's Avatar
Location: The Burbs of NYC, where you can park your car on the street & they wont steal it NY
Send a message via AIM to deemack79
Just PM'd.....
EJ8 Squad Member #396
deemack79 is offline   Reply With Quote
Old 01-14-2009, 05:59 PM   #4
OMG THE GOGGLES
OMG THE GOGGLES's Avatar
Originally Posted by modernhonda View Post
Thanks man! Be safe over there, and remember NO GOGGLES!
Why no goggles?
OMG THE GOGGLES is offline   Reply With Quote
Old 01-15-2009, 09:40 AM   #5
modernhonda
H-T Basic Sponsor
Old 01-15-2009, 11:36 AM   #6
deemack79
deemack79's Avatar
Adam hooked me up! Should have 'em mid next week....can't wait!
Old 01-15-2009, 03:26 PM   #7
Cuda
Cuda's Avatar
free bump for my next set of coilovers..!!
wonder why that extended top hats is only available for EFs and DAs
"Hermione" (her-MY-oh-knee) n. 94 Civic EX <-- Traded, Not Forgotten
"Persephone" (per-SEFF-oh-knee) n. 99 Civic EX <-- Current
Cuda is offline   Reply With Quote
Old 01-17-2009, 07:36 PM   #8
Gant
2006 Honda Prelude
Gant's Avatar
Send a message via AIM to Gant
how do you adjust pic coilovers? these type of coilovers confuse me do you adjust AT THE VERY BOTTOM? where the shock is if so what do you do with the top collars?
http://www.707photography.com 707 squad member #2
2001 integra gsr: Stealth alarm 1 - thieves 0
2006 Cbr 600RR
Gant is offline   Reply With Quote
Old 01-23-2009, 12:25 AM   #9
connor53
connor53's Avatar
98 Integra 4 dr shipped to 53545
connor53 is offline   Reply With Quote
Old 01-23-2009, 07:12 PM   #10
Gant
2006 Honda Prelude
Gant's Avatar
You can adjust with the bottom mount in order to keep full stroke out of the coilover/strut. If you need more of a drop you can lower the upper collars.
ok so if i get these do i play with the top collars at all? im not going for a slammed look just lowered right to the tire
PM price for 2001 integra gsr shipped to 94589
2006 Cbr 600RR
Old 01-24-2009, 05:29 PM   #11
2001B18C1GS-R
2001B18C1GS-R's Avatar
Send a message via AIM to 2001B18C1GS-R
pm price shipped for my 01 integra on pic coilover thanks and spring rates
2001B18C1GS-R is offline   Reply With Quote
Old 01-29-2009, 07:56 PM   #12
barely4dr
barely4dr's Avatar
Send a message via AIM to barely4dr
how much for LCA's shipped to 91016 for EF application?
ABDC: Rhythm City shoulda won!
FS: 4x100 brake assembly w/extended studs
EF Sedan Squad Member #38
barely4dr is offline   Reply With Quote
Old 01-30-2009, 08:56 AM   #13
DCivic00
DCivic00's Avatar
Send a message via AIM to DCivic00
How much for a set of the coilovers for a DC sent to 33328?
DCivic00 is offline   Reply With Quote
Old 01-30-2009, 06:01 PM   #14
13sechatch
13sechatch's Avatar
Send a message via AIM to 13sechatch
pm price on coilovers for 98 teg shipped 40515 thanks
ShorTuned
Fully built all motor b18c 13:1 compression: 208whp
13sechatch is offline   Reply With Quote
Old 02-01-2009, 06:25 AM   #15
tai_mishuu911
tai_mishuu911's Avatar
Send a message via AIM to tai_mishuu911
great stuff! ordered mine awhile back
price on lca's with oem bushings for an ek shipped to 33772
Buddy Club | PIC | Carbing | Precision | Hondata | Greddy | Competition Clutch | LoveFab
tai_mishuu911 is offline   Reply With Quote
Old 02-03-2009, 09:40 AM   #16
samace_sg
samace_sg's Avatar
how much for select coilovers for 94-01 Integra
samace_sg is offline   Reply With Quote
Old 02-10-2009, 08:16 AM   #17
hellajdmyo
New User
pm me 94 integra sedan price please
hellajdmyo is offline   Reply With Quote
Old 02-11-2009, 01:04 AM   #18
TheJunBuilt
TheJunBuilt's Avatar
pm ed!
www.Dynotuned.com
Tuning Available: AEM, Hondata, Uberdata and many more
d.t.p turbo kits! (608-663-dyno) mikejones sent you!
TheJunBuilt is offline   Reply With Quote
Old 02-11-2009, 11:10 AM   #19
TheJunBuilt
pm sent
www.Dynotuned.com
Old 02-12-2009, 03:30 PM   #20
mightymaxgst
mightymaxgst's Avatar
Send a message via AIM to mightymaxgst
can you pm me what spring rates you have and shipped to 33559? thanks
mightymaxgst is offline   Reply With Quote
Old 02-14-2009, 02:33 AM   #21
ww evo ix
ww evo ix's Avatar
pm me price for 96 hatch w/spring rates..
do you have a package deal that includes coilover,lca,and camber kit?
For SALE 99-00 Front end Conversion ---->> http://hondamarketplace.com/showthread.php?t=2568319
ww evo ix is offline   Reply With Quote
Old 02-15-2009, 10:21 AM   #22
ww evo ix
ww evo ix's Avatar
thanks for the pm ... we'll let you know in a few days...
Old 02-17-2009, 01:33 AM   #23
00jdmdc24sale
00jdmdc24sale's Avatar
Send a message via AIM to 00jdmdc24sale
need a price for 88 honda crx bushing kit
00jdmdc24sale is offline   Reply With Quote
Old 02-17-2009, 09:24 AM   #24
NBPej1
NBPej1's Avatar
Local bump!
Can you guys get the Selects?
Originally Posted by TheMuffinMan View Post
Bullshit asshole, no one likes the tuna here!
I ♥ my coupe
NBPej1 is offline   Reply With Quote
Old 02-17-2009, 09:43 AM   #25
Jason.H.
Send a message via AIM to Jason.H.
bump for awesome products. ive used pic select in 12k 14k for 2 years now on my 2000 civic. they have seen alot of track time at vir, cmp, and roebling road. and i daily drive it on the street. the guys that own the company (allen and tim i believe) are super easy to deal with and are great guys that are always out at the track days for nasa with honda challenge. go to picperformance.com to check the specs on their stuff.
Jason.H. is offline   Reply With Quote
1z, adjusting, bushings, coil, coilovers, crx, cuda, front, number, overs, performance, pic, picperformance, select, tracking, type
